Designing a 40″ Sliding Cargo Tray for my Sprinter Van
Forums » Project Forums » Vehicle Projects » Designing a 40″ Sliding Cargo Tray for my Sprinter Van
Author
Topic
#36581
Don’t know what the deal is with not being able to find cargo trays in just about every size. You’ve got companies like MORryde that make a lot of sliding trays, but then again… not really. I mean they have several sizes! But you can’t get get them in like every inch increment you might want.
Anyway, I need a 40″x40″ sliding tray for the back of my Sprinter van, so since there isn’t one out there I decided to design it myself. To start with, I’m designing this to work with some basic Amazon 40″ locking slide rails.
71k1ZzloFQL._AC_SL1500_
The worst part of this is that they don’t have any models of the rails that you can use to figure out where all the holes are, so I just ordered the set and then measured all the holes by hand. I then used them to design a set of mounts to bolt to the floor of the van.
Mounting-Rails
The good news is that once one side was designed, it just needed to be mirrored to create the other. They are identical – they just have to be bent in opposite directions when it’s time for that.
Next, I worked on the tray design. The outer dimensions are actually 40.25″ in both directions, with an ID of 40″. The tray is to be made from 1/8″ aluminum, with 2″ flanges on the sides, and 1″ flanges front and back. The slides are each .75″ thick, so the overall width with the tray mounted with the slides will be right at 42″, which is about what I have available in my Sprinter.
Now, the goal is to be able to put 500 pounds on this tray, and the aluminum is a little thin for my liking.
Tray
So to stiffen it up a bit, I’m adding a couple of channels underneath that will be welded in place.
Supports
Speaking of welding, the corners will be fully seam welded to help make it more rigid.
Corners
Finally, I want to be able to secure things to the tray since I’ll be driving around, so I’m adding a ton of holes that can be used for either bolting through, or preferably to add nutcerts and just bolt into. I’m also adding some L-track slots so that standard tie-downs can be used.
Slots
So basically this requires 5 parts – the tray and it’s two stiffeners, plus the two slide mounts. Parts have to be laser cut, bent, then powder coated. But after that the rails just have to be bolted on and the mounts secured to the floor in the van! That’s as far as I’ve gotten, but it’s time to commit to metal now. I’ll give more updates later.
I think this would be a relatively simple task to change the dimensions on the trays. The only tricky part is that each of the sliding rails will have a different hole pattern. So it would make much more sense to go with rails from a vendor that publishes actual models of their parts so they can be incorporated into the models and not require manual, potentially inaccurate, measurements.
John P.
Texas Metal Works
Founder
1 user thanked author for this post.
Donald P. (December 14, 2025)
Viewing 1 reply thread
Author
Replies
  • #36865
    I forgot to give an update on this, but I got the tray built (and I mean that literally because I didn’t do it, the guys in the shop did :-). And I test fit it in the back of the van and it’s awesome!
    So now it’s at powder coating, getting a nice textured black treatment. Once it’s complete and I get it installed I’ll share the results.
    John P.
    Texas Metal Works
    Founder
  • #36870
    Time for another update… The parts are back from powder coating and everything is textured black. Here’s what it looks like bolted into the back of the Sprinter.
    And when it’s extended…
    The L-Track slots take any of those kinds of attachments, but I’m most interested in using the tie down points like this.
    I also inserted nutcerts into all of the perimeter holes, and might do more later, but those allow us to bolt things to the tray. The idea is that if there is something that needs to be mounted to the tray securely we can make brackets or something and bolt them down.
    Since I have almost 40″ of height and there are a lot of things that don’t need anywhere near that kind of space, I am really interested in designing a bolt on second level or something. First I need to decide what is going to go on it, but for example I have a little travel grill. That could easily be elevated, and that’s what the nutserts will allow.
    Anyway, that’s probably the final update unless anyone has questions or suggestions. We could make this tray system available as a DIY kit, but not sure if anyone else would really want it, so for now this project will just kind of be parked.
    John P.
    Texas Metal Works
    Founder
    • #37012
      Sweet! I’ve got to put a tool chest on slides to mount on the base of my DIY weld table build. I actually ordered heavy duty slides from the jungle site that look identical to your picture. I believe the yellow ens are to lock them in place (mine haven’t come in yet)? This will allow me to open the top of the chest if I actually need in the top.
      Sliding trays are the bomb! I also did something similar for the cubby on tow behind camper. It had a cubby that spanned the entire front of the camper, so 8’ wide and was a pain in the rear to reach things that got pushed towards the middle. I actually built my sliding trays so that it was split and I could pull 4’ out on each side.
      Yours is going to work out nicely. Will be extremely handy I’m sure!
  • You must be logged in to reply to this topic.
Quality Guarantee
Premium materials, laser cutting and CNC bending ensure repeatability and success!
Free Shipping
Orders over $899 ship for free! Load up and save, because shipping pallets ain’t cheap.
Made in TEXAS
We don’t cut corners. We engineer for a lifetime. And we do it in Texas, USA!
