How to Format Posts using bbCode
Forums » General Forums » Tutorials » How to Format Posts using bbCode
Tags:
Author
Topic
#3856
A Beginner’s Guide to Using BBCode
BBCode (Bulletin Board Code) is a simple markup language used to format posts in forums and other online platforms, like the one on this site. It uses tags enclosed in square brackets [ ] to tell the website how to display your text. It’s an easy way to add formatting like bold text, images, or lists without needing to know complex HTML.
Below is a guide to the BBCode tags available here, showing how to use them and what they do.
Basic Formatting
Bold Text
  • Purpose: Makes the enclosed text appear bold.
  • Syntax: [b]Your text here[/b]
  • Example Output: Your text here
Italic Text
  • Purpose: Makes the enclosed text appear italicized.
  • Syntax: [i]Your text here[/i]
Underlined Text
  • Purpose: Underlines the enclosed text.
  • Syntax: [u]Your text here[/u]
Strikethrough Text
  • Purpose: Puts a line through the enclosed text.
  • Syntax: [s]Your text here[/s]
Subscript
  • Purpose: Makes text appear slightly lower than the normal line (subscript).
  • Syntax: H[sub]2[/sub]O
  • Example Output: H2O
Superscript
  • Purpose: Makes text appear slightly higher than the normal line (superscript).
  • Syntax: E=mc[sup]2[/sup]
  • Example Output: E=mc2
Text Appearance
Font Size
  • Purpose: Changes the size of the enclosed text. Use a number (size in pixels).
  • Syntax: [size=20]Large text[/size]
  • Example Output (Conceptual): Large text (Actual appearance depends on site CSS)
Font Color
  • Purpose: Changes the color of the enclosed text. Use standard color names (e.g., red, blue) or hex codes (e.g., #FF0000).
  • Syntax (Name): [color=blue]Blue text[/color]
  • Syntax (Hex): [color=#008000]Green text[/color]
  • Alternate Tag: [colour=...] also works.
  • Example Output: Blue text, Green text
Font Family
  • Purpose: Changes the font type of the enclosed text (if the font is available).
  • Syntax: [font=Arial]Arial text[/font]
  • Example Output: Arial text
Highlight
  • Purpose: Adds a background color to the text, like using a highlighter pen.
  • Syntax (Default): [highlight]Highlighted text[/highlight]
  • Syntax (Color): [highlight=yellow]Yellow highlighted text[/highlight]
  • Example Output (Conceptual): Highlighted text (Default color depends on site settings)
Layout and Structure
Line Break
  • Purpose: Inserts a single line break.
  • Syntax: [br]
  • Example Output: Creates a break
    like this one.
Horizontal Rule
  • Purpose: Inserts a horizontal dividing line.
  • Syntax: [hr]
  • Example Output:
Text Alignment
  • Purpose: Aligns the enclosed text (or other elements) to the left, center, right, or justifies it.
  • Syntax (Left): [align=left]Left-aligned text.[/align]
  • Syntax (Center): [align=center]Center-aligned text.[/align]
  • Syntax (Right): [align=right]Right-aligned text.[/align]
  • Syntax (Justify): [align=justify]Justified text block...[/align]
  • Example Output (Center):
Code Block
  • Purpose: Displays preformatted text or code, often in a monospaced font and preserving whitespace.
  • Syntax: [code]Your code here...[/code]
  • Syntax (with Language): [code=css].example { color: red; }[/code] (Language highlighting depends on site setup)
  • Example Output:
    Your code here...
Anchor
  • Purpose: Creates a named point in the page that can be linked to directly.
  • Syntax: [anchor=section1]This is Section 1[/anchor]
  • Example Output: Creates an invisible anchor named ‘section1’. You could link to it using a URL like yourpage.html#section1.
Links and Images
URL (Link)
  • Purpose: Creates a clickable hyperlink.
  • Syntax (Simple): [url]https://www.google.com[/url]
  • Syntax (Named): [url=https://www.google.com]Visit Google[/url]
  • Example Output (Simple): https://www.google.com
  • Example Output (Named): Visit Google
Email Link
  • Purpose: Displays an image.
  • Syntax (Basic): [img]https://via.placeholder.com/150[/img]
  • Syntax (With Dimensions): [img width=100 height=50]https://via.placeholder.com/150[/img]
  • Syntax (With Alignment): [img align=right]https://via.placeholder.com/150[/img]
  • Example Output (Basic): Displays the image from the URL. (Actual image omitted here)
Lists
Unordered List (Bullets)
  • Purpose: Creates a bulleted list.
  • Syntax:
    [list]
    [*]First item
    [*]Second item
    [*]Third item
    [/list]
  • Example Output:
    • First item
    • Second item
    • Third item
Ordered List (Numbers)
  • Purpose: Creates a numbered list.
  • Syntax:
    [list=1]
    [*]Step one
    [*]Step two
    [*]Step three
    [/list]
  • Example Output:
    1. Step one
    2. Step two
    3. Step three
Ordered List (Letters)
  • Purpose: Creates a list ordered with lowercase letters.
  • Syntax:
    [list=a]
    [*]Option A
    [*]Option B
    [*]Option C
    [/list]
  • Example Output:
    1. Option A
    2. Option B
    3. Option C
John P.
Texas Metal Works
Founder
  • This topic was modified 10 months ago by John P..
Viewing 0 reply threads
Author
Replies
  • #3862
    There is also another special one that we probably don’t need here, but it’s fun anyway…
    Spoiler
    • Purpose: Hides content until the user clicks to reveal it. Good for hiding answers, sensitive details, or large blocks of text.
    • Syntax (Default Title): [spoiler]This content is hidden.[/spoiler]
    • Syntax (Custom Title): [spoiler=Click to Reveal]This content is hidden.[/spoiler]
    • Example Output:
    This content was hidden until you clicked!
    John P.
    Texas Metal Works
    Founder
  • You must be logged in to reply to this topic.
Quality Guarantee
Premium materials, laser cutting and CNC bending ensure repeatability and success!
Free Shipping
Orders over $899 ship for free! Load up and save, because shipping pallets ain’t cheap.
Made in TEXAS
We don’t cut corners. We engineer for a lifetime. And we do it in Texas, USA!
